Hi Dan,
Sorry we haven't yet figured out how to trajectory plan 3rd order motion through complex paths while obeying all Jerk, Acceleration, Velocity, and position constraints of all the
axes. It is a very complex problem.
You should be aware that you can set different accelerations for 2nd order motion and 3rd order motion (rapids).
There is an option to apply some low pass filtering to the motion trajectory. This can reduce Jerk spikes significantly at the expense of slight trajectory errors. See the section on Low Pass Filter (KLP) here:
From: "'Dan' engnerdan@... [DynoMotion]" <DynoMotion@yahoogroups.com>
Sent: Wednesday, October 22, 2014 3:24 PM
Subject: [DynoMotion] 3rd Order Coordinated Motion
A
while back you said that g-code is run as a 2nd order move (no jerk) and rapids
are a 3rd order. Can you tell me why g-code is not run as a 3rd order move?
I
ask because the hard acceleration of not having the jerk in the calculation is
forcing me to turn my acceleration way down to keep the movement smooth. Even a
small amount off jerk would greatly improve the performance of my machine.
